GEEETECH I3 PRO B Position Axes
Posted: Sat Aug 25, 2018 7:05 pm
by joschihb
We have a problem with our GEEETECH I3 PRO B.
If the printer is running on Auto Home, the display does not show X0 Y0 Z0 but other values. When moving the axes, the position is not controllable.
For clarification, we have attached a video.
Thanks for your help
J.Kolano
Germany
https://youtu.be/8Yh0qQybqVU
Re: GEEETECH I3 PRO B Position Axes
Posted: Thu Aug 30, 2018 8:09 pm
by jzero42
Move it carefully with the motor control menus (X,Y) to the actual CORNER of the glass sheet.
Find the menu "Set home position" (that's the English phrase), it will then zero it. Make sure to then use the "Store settings" menu to save to EEPROM.
After that, you will find that "go to home" will go to a slightly negative position, but that's fine.
