Centering A10 Printer
Tyrant
Post by Tyrant »
Hi , Just received and completed putting together the A10. Starting a first test print and the printer is well off center. Can anyone advise the best way to ensure prints always start centrally ?
Thanks in Advance.
MichaelK
Re: Centering A10 Printer
Post by MichaelK »
Hello :)
First,check the size of the heatbed please.
The printer will be selling with a 220x220 bed and optional you can sell a 230x230 bed.
My own presale A10 using a 230x230 heatbed.
I made my own firmware to correct the size into the Marlin firmware, this is the only way to do it!
You found them into my footer.
(Update) I'ved made a mistake, you can set correction values into Cura to setup the bed. :ugeek:
:mrgreen:
Slicer software manages the position of the model.
If you have verified the printer's parameters correctly, you can control the starting position at which you want the printing process to start.
Tyrant
Post by Tyrant »
thanks for the quick response, i'm a total noob when it comes to 3d printing. How do i go about verifying the parameters ?
i'm using CURA , latest version for printing.
Oh and measured the Bed , 224x224
just to add a bit more to this. when i begin a print the heat bed moves backward to the very end of the rail , rattles about a bit , and same goes for the nozzle before it starts printing . is that normal?
MichaelK
Post by MichaelK »
Printersettings in Cura.
Left side: heatbed
Right side: Postion from the extruder
Tyrant
Post by Tyrant »
thanks ,
i'll try this , my heat bed is just over 220 , so i'll modify the numbers to reflect that.
Tyrant
Post by Tyrant »
ok, Tried these settings , prints still way off to the right on the heat bed and off it.
MichaelK
Post by MichaelK »
Tyrant
Post by Tyrant »
Thanks Michael , this will help !! , it's getting there now , appreciate the help!!!!
