Configuration when changing controller board model
Posted: Mon Sep 03, 2018 5:51 am
by no1jester
Ok so after a lot of printing and testing i went back to an older version of firmware i then went back to the new firmware made the minor adjustments i need to (mainly the fact that i can print a larger volume so just adjusted those settings) and now everything is working perfect :)
Hi All
Ok so i got my printer working really well and then i upgraded the board from a 2560 REV A to a GT2560 Rev A+
I have all the parameters for the Printer please see below
now my issue is.
1. When i print a cube i either get a rectangle like its printed a cube ontop of the cube
OR
2. I get this 5mm thick cube
So i beleive it has something to do with the stepping because well yes i beleive i have a T8 threaded rod i did forgeti to do the command and thats when i got the rectangle then when i did the command i get 1/4 of a cube i have included some pics as well.
I have increased the Flow to 150 and the printing temp to 10 and i got a very clean print but still not a square.
I have given the comand to as described in the instructions (i have a PRO B by the way)
I am at a loss any help is apreciated.
Just a quick edit i have
M8*L300mm Z-axis screw so i do think this is the issue but not 100% sure
Ok so another update:
I Printed a 20cm cube it still comes out 41cm so i adjusted to the following settings (Z axis only)
#define DEFAULT_AXIS_STEPS_PER_UNIT {80,80,1219.047,93} // MXL, Z M8=1.25, MK8
however there is still no change it still prints a 41cm cube
Speed: 100
Flow: 100
Min 180 <-- i set this low due to printing at 185 with wood (wirked great with baby groot on the 2560 board)
Max 250
Fact 000.10 (mm)
PID-P: +022.20
PID-I: +001.08
PID-D: +114.00
PID-C: 1
Accel 1000
Vxy-jerk: 20
Vz-jerk: +000.40
Ve-jerk: 5
Vmax x: 500
Vmax y:500
Vmax z:2
Vmax e:25
Vmin 0
Amax X:1000
Amax Y:1000
Amax Z:100
Amax E:10000
A-retract 1000
Xsteps/mm: +080.00
Ysteps/mm: +080.00
Zsteps/mm:+4020.0
Esteps/mm:+0096.0
threaded rod.jpg (181.05 KiB) Viewed 3967 times
img 1.jpg (95.85 KiB) Viewed 3967 times
