Page 1 of 2
Z axis rate issue plus other issues
Posted: Tue Oct 16, 2018 6:06 am
by macray76
So I have the major issues with my A30 right now that I hope you can give some help with please.
1. The z axis is going up and down at different rates. I tried increasing the z A4988 driver to 1.1V with no change in the issue. I even reduced the voltage down to 0.6V again without it fixing the issue.
I can now easily replicate the issue by simply homing the axis, set point 5 (it doesn't matter which point) on the manual levelling page, adjust the z offset so it has friction against the paper. Then press 5 again to make the nozzle lift and drop. It does not drop to the same level as before and sits above the heat bed by around 2mm.
If I were to re-level and drop the nozzles down those 2mm, on print the nozzle will scratch the bed. Therefore the true z height is after homing and not on the second press of point 5.
Issue 2: this could be related to issue 1. I readjusted my xyz motor steps using the smartto motor tool after printing the xyz calibration cube. However, my prints are now failing at about 4mm height. The print head slows down to a near standstill and then after a short while the print pauses. Resuming it makes it print for another second before it pauses again. When I set the motor steps back to default settings the print no longer fails.
Issue 3: with the above two issues I thought I should downgrade my firmware to V1.36.57. I am currently running V1.38.61 but it looks like that firmware was withdrawn after release and 1.36.57 is the stable release. I downgrade the main board using the smartto tool and then I copy the relevant 1.36.57 LCD files onto the LCD SD card including the A30.bin file. However, on boot I can't control the printer. No temperatures are shown and I can't select the Settings option. I have to reflash 1.38.61 to get the printer working again.
Any help greatly appreciated as always.
Re: Z axis rate issue plus other issues
Posted: Tue Oct 16, 2018 6:28 am
by apak
Try this one
http://www.geeetech.com/firmware/A30%2037.58.zip
May be you need to manual update lcd fw
Posted: Tue Oct 16, 2018 3:03 pm
by macray76
Thanks I managed to update the firmware finally after using a different SD card in the side of the machine when upgrading the LCD firmware.
Posted: Wed Oct 17, 2018 4:03 pm
by macray76
Hi all.
Would someone be so kind and replicate the following steps on their A30 and see if you get the same result as me please?
1. Home all the axis
2. Select manual levelling
3. Press point 5
4. Use the Z UP or Z DOWN to adjust the z-axis level (this is important - you must press a button at least once) so that you have a paper-width gap
5. Press point 5 again (although the same behaviour occurs when selecting another point)
Does your nozzle now sit around 2mm higher than it was before (i.e. you can now fit a lot more than a paper-width between the bed and nozzle)?
It does on mine and only homing the axis again and starting manual levelling from scratch returns the z-axis back to the correct level. Even if you press the OK button between steps 4 or 5 I get the same behaviour.
It seems like anytime you press the Z UP or Z DOWN button it thinks the z-axis is 2mm higher than it should be. You have to home the axis before you can select another levelling point.
Posted: Sun Oct 21, 2018 10:32 pm
by Miceltu
Yes, it is the same by me.
In fact I have a printer whom not can start to print, because the first level did not fit.
And the "Super Plate" is "super scratched" now. What a frustration.
Posted: Wed Oct 24, 2018 3:53 am
by apak
Yes, It´s a bug. After you move any Z offset during leveling, you need to exit a reenter.
I manage to level 5, exit, enter level again al do 1,2,3,4 points....but no Z offset,just the knob
Posted: Fri Oct 26, 2018 8:46 pm
by Lexan
pls keep in mind, the offset in the manual leveling system is no mesh offset.
try to keep the offset at 0 and level with the screws below the headbed.
at this point check also that there is enough spring tension to hold the wheel in place so it cant move du tue vibrations.
and last but not least, dont touch the adjustmentwheel when you move the paper
Posted: Sat Oct 27, 2018 6:58 am
by apak
Sure, I go to position 5, use offset to fine level that position, and then go to all others positions to only uses leveling knoobs
Posted: Sat Oct 27, 2018 8:31 pm
by Lexan
apak wrote: Sat Oct 27, 2018 6:58 am Sure, I go to position 5, use offset to fine level that position, and then go to all others positions to only uses leveling knoobs
no, you just use the knobs for leveling and let the offset on 0
Posted: Mon Oct 29, 2018 4:49 pm
by apak
not really, because I had removed the superplate, add a 3 mm aluminum plate, and pei, so I do have an offset to deal with, but anyway, LCD .37 FW has a bug.
If you use during manual leveling any offset, and then move to any of the mesh point, I t doesn´t go down all the way.
but if you exit manual level and go back to it, and don´t touch z offset bottons, nozzle DOES bock down to where it should.
