Simplify3d control panel stop print firmware not responde
Posted: Sun Oct 21, 2018 10:48 pm
Hi at all,
I'am buy a Geeetech A30 hardware version 2.
If I print with file after the self-leveling it generates three beeps and stops the print.
The start script I use:
The end script I use:
I have to decide to upgrade the firmware at 1.36.57, after upgrade is missing serial nember and version of hardware and I not resolve the problem of print to file.
I using the consol of simplify 3d, i have print an object of 2 hour of printing and is ok.
I sent two objects to print for a total of 6 hours of printing, after 4 hours of printing it stopped showing the following error:
etc
Can you help me?
Best regards
Code: Select all
G21 ;Imposta unità di misura in millimetri
G90 ;sistema di coordinate assolute
G28 ; Riporta tutti gli assi a zero
G29 ;test autolivellamanto
G92 E0 ; reset extrusion distance
Code: Select all
G28 X0 ; home x axis
M106 S0 ; turn off cooling fan
M104 S0 ; turn off extruder
M140 S0 ; turn off bed
M84 ; disable motorsI using the consol of simplify 3d, i have print an object of 2 hour of printing and is ok.
Code: Select all
BEDS: ok T: 185.2 /185.0 B: 59.2 /60.0 F: 100 R: 100 @: 0 B @: 0
SENT: G1 X77.870 Y171.650 E3.9613
ATTENTION: The firmware is not responding. Attempt to force the continuation in progress ...
SENT: M105
SENT: G1 X76.570 Y171.650 E4.0045
SENT: M105
SENT: M105
SENT: M105
SENT: G1 X76.570 Y129.100 E5.4198
SENT: M105
SENT: M105
SENT: M105
SENT: M105Can you help me?
Best regards
