3dtouch sensor pin doesn't go down
peppe_bot
Post by peppe_bot »
Hi, I've recently got my 3dtouch. I've used the firmware 1.1.9, for the configuration file I've used the one that is in: example_configurations\Geeetech\Prusa i3 Pro B\bltouch, now the problem is that when I send G28 to my printer x and y are ok the problem is with z axis, in fact the pin of the sensor doesn't go down. Maybe is some configuration that doesn't match with the original bltouch, sending M280 P0 S120 the sensor works fine. Any suggestion? thanks :)
CoffeeBeans
Re: 3dtouch sensor pin doesn't go down
Post by CoffeeBeans »
This seems to be the same issue I am facing. I've tried searching around online but have yet to find a solution to this. Does your print head move to the center and then just push the extruder into the glass?
CoffeeBeans
Hey,
I finally managed to fix this issue after lots of errors and the printer appears to be working (although I need to work on the calibration). Make sure you download and have this firmware installed;
http://www.geeetech.com/forum/download/file.php?id=3703
It should already have all of the pins correctly setup and the configuration.h does not need to be edited (This is for REV A+). Flash the new firmware and run the probe commands and it should work. From here you just need to work on the calibration, this video is extremely helpful;
https://youtu.be/y_1Kg45APko
joolz
Post by joolz »
I am having the same issue with my i3 Pro B, I have tried downloading the firmware but when I compile I get an error.
Arduino: 1.8.9 Hourly Build 2018/12/11 04:33 (Windows 10), Board: "Arduino/Genuino Mega or Mega 2560, ATmega2560 (Mega 2560)"
Code: Select all
                 from sketch\BlinkM.cpp:5:
 #define X_MAX_PIN          -1
 #define X_MAX_PIN 24
 #define Y_MAX_PIN          -1
 #define Y_MAX_PIN 28
                 from sketch\thermistortables.h:4,
                 from sketch\Configuration.h:792,
                 from sketch\Servo.cpp:44:
sketch\Marlin_main.cpp:2667:36: warning: invalid suffix on literal; C++11 requires a space between literal and string macro [-Wliteral-suffix]
                 from sketch\cardreader.h:8,
SdBaseFile.h:38:8: error: using typedef-name 'fpos_t' after 'struct'
 struct fpos_t {
c:\users\rowjoo\desktop\3d printing\arduino-nightly-windows\arduino-nightly\hardware\tools\avr\avr\include\stdio.h:950:33: note: 'fpos_t' has a previous declaration here
sketch\Marlin_main.cpp: In function 'void set_bed_level_equation_lsq(double*)':
sketch\Marlin_main.cpp:998:36: warning: ISO C++ forbids converting a string constant to 'char*' [-Wwrite-strings]
     planeNormal.debug("planeNormal");
                 from sketch\ConfigurationStore.cpp:1:
                 from sketch\cardreader.cpp:1:
                 from sketch\qr_solve.h:1,
                 from sketch\qr_solve.cpp:1:
                 from sketch\cardreader.cpp:2:
 struct fpos_t {
                 from sketch\MarlinSerial.cpp:23:
exit status 1
                 from C:\Users\rowjoo\Desktop\3D Printing\Firmware2\Marlin-PI3_Pro_B_3DTouch (A+)\Marlin-PI3_Pro_B_3DTouch (A+)\Marlin\Marlin.ino:33:
                 from sketch\digipot_mcp4451.cpp:1:
                 from sketch\SdFatUtil.cpp:20:
                 from sketch\motion_control.cpp:22:
                 from sketch\Sd2Card.cpp:20:
                 from sketch\SdBaseFile.cpp:21:
                 from sketch\SdFile.cpp:20:
In file included from sketch\SdBaseFile.cpp:24:0:
 struct fpos_t {
sketch\SdBaseFile.cpp: In member function 'void SdBaseFile::getpos(fpos_t*)':
SdBaseFile.cpp:298:8: error: request for member 'position' in '* pos', which is of non-class type 'fpos_t {aka long long int}'
   pos->position = curPosition_;
SdBaseFile.cpp:299:8: error: request for member 'cluster' in '* pos', which is of non-class type 'fpos_t {aka long long int}'
   pos->cluster = curCluster_;
sketch\SdBaseFile.cpp: In member function 'void SdBaseFile::setpos(fpos_t*)':
SdBaseFile.cpp:1496:23: error: request for member 'position' in '* pos', which is of non-class type 'fpos_t {aka long long int}'
   curPosition_ = pos->position;
SdBaseFile.cpp:1497:22: error: request for member 'cluster' in '* pos', which is of non-class type 'fpos_t {aka long long int}'
   curCluster_ = pos->cluster;
                 from sketch\SdFile.cpp:23:
 struct fpos_t {
                 from sketch\SdVolume.cpp:20:
Julian
