FAQ-Geeetech E180 Mini 3D printer
Posted: Sat Nov 10, 2018 3:40 pm
by Admin
Drivers
The printer cannot communicate with computer?
Check the USB serial chip at first:
http://www.geeetech.com/forum/viewtopic ... 21&t=60612
Firmware
1.How to upload firmware?
You need to upload the firmware via Smartto Toolkit
http://www.geeetech.com/forum/viewtopic ... 222#p82222
2. How to change the motor direction in the firmware?
http://www.geeetech.com/forum/viewtopic ... 054#p82054
Motor
1.Motor’s non-action
3.The motor can move at one direction only
1)Check the wires of the endstop loose or not
2)You need to check the endstop work or not
viewtopic.php?f=17&t=60927
3)Swap the a4988
LCD
1.If you find your LCD shows white only or abnormal,you need to reflash the LCD files
http://www.geeetech.com/forum/viewtopic ... 64&t=60677
Extruder
1.Extruder does not work normally.(You need to check the temp of it is correct )
2.If you find the "Nozzle 0 temp",you can check the contact point of the nozzle.
You can use the soft cloth clean it
contact point.png (237.82 KiB) Viewed 25776 times
Level
1.Manual level
Source
1.Wires of the Mainboard: GTM32 MINIS
GTM32 MINI E180 wires.png (1.06 MiB) Viewed 25467 times
2.Schematic for GTM32 MINIS
https://github.com/Geeetech3D/Diagram/b ... MINI_S.pdf
(being updated)
If this information cannot cover your problems, you can join our Facebook group, and get help from our technical support team or have a detailed discussion with other customers in time.
