Page 1 of 4
3dTouch issues - probing failed
Posted: Tue Dec 18, 2018 4:12 am
by RobOC
After ages faffing about, I thought I'd made some progress and finally got the 3dtouch responding to commands.
However, its unreliable, if I select bed levelling it moves to a couple of points and seems to be working fine, then on the third point just crashes into the bed. The light goes out as expected but it doesnt seem to react.
I'm at a loss as to what I should be troubleshooting next, any thoughts?
Thanks,
Rob
Re: 3dTouch issues - probing failed
Posted: Sun Dec 30, 2018 6:40 am
by jzero42
Did you get the (original) Geeetech 3DTouch probe? There are a lot of fake ones on eBay which are bad quality.
I got a Geeetech one and it works great!
Posted: Wed Jan 20, 2021 8:27 pm
by MeghanBlair
The view of the topic is linked for the attachment for the field. Prospects of the turns and best proofreading services are fit for the attachment for the field. The thing is held for the implied forces for the top of the topics.
Posted: Sat Jan 23, 2021 6:11 pm
by jamestinker
There are many writing companies operating in the UK, but Law Essays Help reserves the title of the best law essay help UK. Since this title has been given to us by our service consumers, we pledge to continue providing quality services at cheap rates.
Dell Service Center in Tardeo
Posted: Mon Feb 15, 2021 5:09 pm
by nsslaptop
You can either do a broad examination about various organizations and make a rundown of cost and execution correlation or basically go to Dell Service Center in Tardeo to get another laptop that satisfies every one of your necessities under one rooftop. Here, you can get a laptop, work area, tabs and excellent adornments.
Posted: Wed Feb 24, 2021 4:51 pm
by DavidHarsh
Usually, people are facing these types of issues and now you should read the blog of assignments UK that was discussing about these issues. Maybe you can take help with their blogs. I get interesting information from their blogs.
Posted: Fri Feb 26, 2021 1:29 pm
by Massey457
RobOC wrote: Tue Dec 18, 2018 4:12 am Hi,
However, its unreliable, FaceTime if I select bed levelling it moves to a couple of points and seems to be working fine, then on the third point just crashes into the bed. The light goes out as expected but it doesnt seem to react.
Thanks,
Rob
I assumed that this de-powering is only during the actual probe lowering, so very short. So I figured that this might be an EMI problem. In a last resort I updated to Marlin 1.1.9 which has the functionality to shut the power off for heater and bed and everything now seems to work perfectly. I now see that the de-powering is a bit longer and in fact the extruder temperature drops slightly, this has never been seen with the previous firmware version.
Best Chiller Truck Transport Services
Posted: Fri Mar 19, 2021 3:21 pm
by albertmay1988
REDLINK CARGO is readily providing chiller truck transport services in Dubai for all types of refrigerated products that require a certain amount of temperature throughout the delivery. We are the most well-known and professional transport service providers that can help you to transport your product at the point of deliverance. If you are a food industry, florist, or bio-pharmaceutical organisation, you can easily issue are professional transport services and we can maintain all the standards according to the requirements of your product throughout the process.
Posted: Sat Mar 27, 2021 3:27 pm
by jadewyatt26
3D Touch is an element of some fresher iPhone screens that permits the presentation to recognize actual pressing factor, and afterward react with a product activity. For instance, you would 3d be able to Touch on some application symbols and add gadgets to the Today Widget screen that way. Or then again you would 3d be able to Touch to print PDF, or utilize 3D Touch as a trackpad of sorts on iPhone with a slick console stunt, among numerous extra accommodating or helpful, and different abilities. With how helpful 3D Touch can be, it's justifiable why iPhone clients would be irritated if the element is abruptly not working. best dissertation help
Posted: Wed Mar 31, 2021 6:09 pm
by Schulte854
Thanks,
Rob
Not long after the "update"/"fix" the problem manifested itself again... Further troubleshooting revealed that it was a bad connection of the connectors of the sensor that got temporarily "fixed" as the cables had been fiddled with during the firmware update.
