I thought I had solved the shifting in the X direction as I hadn't seen it for a month, until my print two nights ago... anyway, things I have tried
I slice in cura, and as I said, I have gotten some successful prints off the pro A, just not a success rate that seems right.
1 - checked the smooth rods on each axis, both by removing and checking, and by swapping out from my old printer (An old Mendel I built 4 years back or so)- returned the geeetech ones to the setup.
2 - belt tightness, a million different ways, swapped the y axis bet holder to another full aluminum that doesn't need whole punch as I was afraid it might be slipping.
3 - replaced the bearings. Greased the bearings, noting that when the belts are disconnected, both axis slide smoothly I didn't expect an improvement, but for completeness tried it.
4 - rebuilt the idlers. replacing the M4 screw with an M3, and slightly opening them up a bit.
5 - opened up the control box, and checked the stepper voltages.... running prints with the steppers at 0.8 (default), at 1.0 and at 1.2. get the slippage on all of them. .. So I also tried taking the stepstick from the 2nd extruder slot, and the connector cable running from board to breakout box on the back and moved that over to the Y axis slots. and saw slipping along the Y again (assuming the X motor stopped, and Y moved at that moment, I then swapped out the X stick and cable. still slipped.
6 - added heat sinks to the stepsticks, with the tiniest drop of thermal paste.
7 - swapped out the motor cables for new ones from the breakout box on the printer to the motors for X and Y. still slippage.
What I will try shortly,
1 - again update the Marlin
2 - replace the ribbon cable maybe?
... and pretty much anything you kind folks might think I missed
