Wich Hotend?
Wich Hotend?
Hello together,
i would like to buy a new Hotend with heatbreaker. On the geeetech Startpage i found this... it shoul fit for the A30 (says the description)
https://www.geeetech.com/geeetech-a10-a ... -1041.html
but mine looks like this: https://drive.google.com/file/d/1zp7RzE ... sp=sharing
would the first one fit? wich do you suggest to use?
Re: Wich Hotend?
I would HIGHLY recommend this one: https://gulfcoast-robotics.com/collecti ... 3d-printer
If you have the 24V A30, just put a note in checkout and ask for 24V electronics.
Re: Wich Hotend?
Are you using that one?
Does it fit in the vanilla A30 out the box? (Cables, mesurements)
How do i know if it is the 24 volt A30?
Sorry for that many questions. I just trying to make sure, i dont mess it up
And thank you for the tip /Advice
Re: Wich Hotend?
Not yet, but I plan to. It's the best E3D V6 clone I could find. Plus, Gulfcoast Robotics has excellent customer support.
You'll need to shorten the wires. I believe this hotend is slightly shorter, so if you plan to use the stock setup you may need to use a mod like this: https://www.thingiverse.com/thing:3135296
Me personally I plan to use a Petsfang: https://www.thingiverse.com/thing:2993902
To figure if you have a 12v or 24v you'll need to open up the control box and read the label on the side of the power supply.
Re: Wich Hotend?
thank for your Help.
I think i messed up my out of the box hotend before a could have clean prints, so i cant print the petsfang ^^
i found a very good rated e3d v6 clone in europe, thats makes it a lot cheaper and will not have to pay any customs
Thanks, very much for that great hint
Re: Wich Hotend?
could you share the the company in Europe who sells the hotends ?
I think mine is also damaged ..
Thanks,
Glenn
Thanks,
Glenn
Re: Wich Hotend?
You have a PNGP46 wrote: Tue Mar 05, 2019 9:19 pm Hi,
Thanks,
Glenn
Re: Wich Hotend?
Would you be so nice to send me a PM with the Info, too?
Thanx!
