Page 1 of 2
Heating Bed only reaches 83°C
Posted: Tue Apr 16, 2019 4:57 pm
by ChrisH90
Hei all, can anybody help me in this: My heating bed only reaches 83°C but in the A30 description it should be max 100°C. What is my failure or what can I do?
Re: Heating Bed only reaches 83°C
Posted: Thu Apr 18, 2019 4:39 pm
I recommend that you use a multimeter to measure the resistance of the hot bed.
The hotbed watt should more than 260W
Posted: Thu Apr 18, 2019 9:06 pm
by ChrisH90
Okay, I will measure if I‘m in office but I think I can not reach the wires. What color of wires are for the resistor? What Ohm should the resistor have. If the Resistance is okay is there any way to increase the power? Is there a limit? I think the PID uses „Pulse-Pause“ - Is there a way to send constant 1 Signal to the heating bed to see if the bed reaches more than 83Degrees?
Posted: Fri Apr 19, 2019 1:36 am
by ChrisH90
Okay, I measured the heating bed. The resistance is 4.2 Ohm. Is that right or is anything wrong with that?
Posted: Fri Apr 19, 2019 9:49 am
Then it should be the hotbed issue.
It should be lower than 2.2Ω
Posted: Fri Apr 19, 2019 12:31 pm
by ChrisH90
Ah okay, so it is 24V when I use Ohms law
Okay, so next step is to go to my reseller?
Posted: Fri Apr 19, 2019 2:01 pm
by _kaktus_
Hello.
Yeah, but...
Heated beds are universal and have a 12V & 24V power connector. Check the configuration.
Posted: Fri Apr 19, 2019 4:31 pm
by ChrisH90
Okay _kaktus_ what do you mean with it? Do you mean the connector on the controller?
Anyway, if I have 12V and 260W the resistance should be at least 0.6Ohm.
Posted: Fri Apr 19, 2019 5:12 pm
by _kaktus_
Hi.
I mean, the leads on the heated bed.
But in fact the resistance of the circuit is inadequate.
- super_plate.jpg (17.56 KiB) Viewed 8578 times
Posted: Fri Apr 26, 2019 6:56 pm
by ChrisH90
Hei all, okay, I got the new heating bed, but also 4,2Ohm between 2 and 3. Between 1 and 2 it is 2,2Ohm but I think I have 24V right?
What if I soldering the wires to 1&2-3? I wondered if in this case the driver is strong enough.
