A30 HW version identification Firmware related
Posted: Thu Apr 18, 2019 11:12 pm
Hi all,
I've just wanted to update or at least modify my A30 firmware mostly because I can't set from the LCD menu Hot-tend temp at 300deg.
First please help me identify the HW version(Equipment model), because in Menu->Settings-> info, is written on A30
but in the firmware I see for example in : XZK_Configuration.h, there is a dependency
I Changed the Configuration_GTM32_Pro_A30S.h with my wished limit temperatures, but no effect after flashing the new build on the A30 motherboard. I'm aware the thermistor on the bed supports currently only 125 deg, but I intend to change it also in the future, I just need to be able to raise it also from menu until the IAR IDE trial expires
Any clues about how to change these values?
Code: Select all
#elif defined(BOARD_A30M_Pro_S)
#include "Configuration_GTM32_Pro_A30M.h"
Code: Select all
#elif defined(BOARD_A30D_Pro_S)
#include "Configuration_GTM32_Pro_A30D.h"
Code: Select all
Code: Select all
#include "Configuration_GTM32_Pro_A30D.h".
