3D Touch Sensor on A30
Posted: Sat May 25, 2019 2:32 am
by Rain426
Help! I have just received the 3DTouch Sensor, and unfortunately it didn't come with any instructions on how to fit it to the A30. I thought it was just a plug in job, but it seems not!
The plug on the extruder which I assume the sensor is meant to plug into has 3 pins.
However there are two connectors on the sensor itself - a 3 pin and a 2 pin.
I also have a whole bunch of random connectors and pins, and what I think is a resistor?
Are there any step-by-step instructions for installing this on a new A30 (just a week old).
Kind Regards,
Ian
Re: 3D Touch Sensor on A30
Posted: Sat May 25, 2019 9:25 am
Posted: Sun May 26, 2019 7:31 am
by Sa1Wales
Looks like he has the Older version of the Hotend as he has'nt got the extruder Expansion board in his pics that is on the new A10 and A30, the youtube video takes him to the Newer Versions.
Steve.
Posted: Mon Jun 10, 2019 2:00 am
by Rain426
Right, turns out I cooked my previous touch sensor
But now I have a new one, plugged in with power. Have updated firmware and the UI files and it seems to be working - however I am having trouble setting it up. I had a look at the below video, which is helpful, but I think there might be some steps missing, as I can't get the leveller to go to the correct level. I just tried a print after thinking I had it set up, and the nozzle proceeded to put a nice scratch in the bed :/
https://youtu.be/7zTJFtwL4O0
Any help would be appreciated! Thanks for the help so far
Posted: Mon Jun 10, 2019 9:13 am
Hi, maybe your 3D Touch is too low. When the z-axis is 0mm, your 3D Touch needs to be installed 1-2mm higher than the hotbed.
Posted: Tue Jun 11, 2019 6:46 am
by Sa1Wales
Rain426 wrote: Mon Jun 10, 2019 2:00 am
When I used mine on my A10 I used to use the small Spanner that come with the printer its 1.5mm(measure the thickness on your printer spanners as long as the thinkness is under 2mm it should be fine, then just carfully slide it under the pin then tighten the screws. I am just suprised you found the right Firmware for the A30 it seems posts and Videos point you to the wrong versions and also versions of the firmware that dont exist. I think out dated posts and videos should be either deleted or updated, I found it A knightmare when I thought the other night Ill try it with the 3d touch then it was like an easter egg hunt to try and find the right Firmware version to use. But Glad you got somewhere with it.
Steve
