Replace motor drivers with TMC2208 or TMC2130
jotadark
Post by jotadark »
hi, I want to improve my printer by changing the driver with TMC2208 or TMC2130, anyone has done it?
Re: Replace motor drivers with TMC2208 or TMC2130
Hi, you can refer to this:viewtopic.php?f=18&t=60658&p=82941&hilit=TMC2130#p82941
I hope this can help you.
:mrgreen:
Some time ago I bought modules with Trinamic chips. :roll:
Unfortunately, the low processing capacity and a lot of activities cause that I haven't conducted any research on improvements in this area yet.
In confidence I'll tell you that I expect to improve the work, and another possibility to increase the speed of the printer.
With our motherboard, there are compatible modules with the TMC2208 driver.
Be very careful when mounting the modules in the sockets. A mistake may result in the destruction of the main µC. :?
If you want to use these on TMC2130 chips it is possible. However, some modifications will be required. ;)
