Good day,
I purchased an I3PC, and have found that the bearing clamps on the X axis have cracked. These are obviously printed parts, perhaps the previous owner has swapped them out and printed using PLA.
Has anyone had experience with replacing them, and what filament did you use to do so? Do you have a link to the STL's that you used? As there are a few on thingiverse I am not 100% sure which are the right ones.
X-Carriage Replacement
Re: X-Carriage Replacement
Hi, you need to loosen the belt and then install the belt clip and adjust the belt to a moderate degree of tightness.
Mr.Hotwire
Hi 'Mr.Hotwire'
How about replacing with these ?
It has to be a better solution ?
https://www.geeetech.com/upgraded-metal ... p-970.html
Gerry
Gerry
Mr.Hotwire
Good idea, I will look into it. I have printed off a set, But I will be doing some modifications to them to help make them more stable.
