Printer stopps at 30mm hight
Posted: Wed Jul 03, 2019 9:10 pm
by Nyemrinju
It is not possible to release a print with the part. now rattles at about 30mm the right engine of the z-axis and it moves not higher!
Hallo,
es ist nicht möglich, einen Druck mit dem Teil rauszubringen. Jetzt rattert bei ca. 30mm der rechte Stepper Motor der Z-Achse und es geht nicht mehr höher.
Re: Printer stopps at 30mm hight
Posted: Thu Jul 04, 2019 9:23 am
Hi, You can check it out.
- Is your lead screw bent?
- Whether the brass nut is too loose or too tight;
- Whether the left and right sides are at the same height, you can refer to this: https://www.geeetech.com/forum
/viewtopic.php?f=65&t=68801
Posted: Thu Aug 08, 2019 12:14 am
by Nyemrinju
I have noticed that the right and left height of the X-axis are adjusted after a few pressure tests. Then the axis moves and the described problem occurs again!
Posted: Thu Aug 08, 2019 9:30 am
Nyemrinju wrote: Thu Aug 08, 2019 12:14 am
Hi, You can check if your left and right threaded rods are bent or missing threads.
It is also possible to check whether the fixing plate of the z-axis is fixedly fastened.
I hope this can help you.
Posted: Sat Aug 31, 2019 9:09 pm
by Nyemrinju
the answer took a while (holidays etc). What I noticed now is that both threaded rods when starting up to a height of about 180mm in the upper bearings are about 3-5mm back and forth. From that height, this movement is over. Is that right and wanted? Are the threaded rods possibly bent or the upper bearings broken?
Posted: Mon Sep 02, 2019 9:02 am
Hi, You can remove the threaded rod for inspection to determine if the threaded rod is bent.
Posted: Sun Sep 15, 2019 8:25 pm
by Nyemrinju
So, I have now finished with this printer and bought the Chiron from Anycubic. This prints right away and how he should! Pity about the wasted time and money!
