How to install the firmware for GT2560 with 3Dtouch
Posted: Wed Aug 07, 2019 11:28 am
hello , ive got a i3 proC im trying to upgrade my printer to 3dtouch , i went to the firmware thread and select :
after that i open with the arduino 1.0.1, select the serial port and the mother gt2560. then i press the compile button and display a error message, i dont know nothing about debug error on arduino.
the next step i do its use the 1.6.8 arduino SW , and do the serial port and board selection.
when i compile i get the following error:
then i try to use the old version
then i went to the cura /repetier and run the note indication for my printer:
please i need some help
then i reemplace the configuration.h from the 3dtouch folder and paste it on the marlin folder.6) Firmware for I3 pro C
Update:
Fixed the endstop error(Default endstop logic status is the"false")
2019/2/27
Marlin 1.1.8 for proC with GT2560VA/A+/2.0
1.Inculde 3dtouch config and no 3dtouch cofing
2.Added the new menu for extruder+hotend
Getech i3 pro C (Marlin 1.1.8 for all).zip
(2.64 MiB) Downloaded 973 times
Code: Select all
In file included from /MarlinConfig.h:40,
from blinkm.cpp:27:
/SanityCheck.h:36:4: error: #error "Marlin requires C++11 support (gcc >= 4.7, Arduino IDE >= 1.6.8). Please upgrade your toolchain."
from blinkm.cpp:27:
SanityCheck.h:295: error: expected constructor, destructor, or type conversion before '(' token
SanityCheck.h:578: error: expected constructor, destructor, or type conversion before '(' token
SanityCheck.h:637: error: expected constructor, destructor, or type conversion before '(' token
SanityCheck.h:749: error: expected constructor, destructor, or type conversion before '(' token
SanityCheck.h:824: error: expected constructor, destructor, or type conversion before '(' token
SanityCheck.h:825: error: expected constructor, destructor, or type conversion before '(' token
SanityCheck.h:826: error: expected constructor, destructor, or type conversion before '(' token
SanityCheck.h:827: error: expected constructor, destructor, or type conversion before '(' token
SanityCheck.h:828: error: expected constructor, destructor, or type conversion before '(' token
SanityCheck.h:829: error: expected constructor, destructor, or type conversion before '(' token
SanityCheck.h:1311: error: expected constructor, destructor, or type conversion before '(' token
SanityCheck.h:1516: error: expected constructor, destructor, or type conversion before 'float'
SanityCheck.h:1516: error: expected unqualified-id before ',' token
SanityCheck.h:1517: error: expected constructor, destructor, or type conversion before '=' token
SanityCheck.h:1517: error: expected unqualified-id before ',' token
SanityCheck.h:1518: error: expected constructor, destructor, or type conversion before '=' token
SanityCheck.h:1519: error: expected constructor, destructor, or type conversion before '(' token
SanityCheck.h:1520: error: expected constructor, destructor, or type conversion before '(' token
SanityCheck.h:1521: error: expected constructor, destructor, or type conversion before '(' token
SanityCheck.h:1522: error: expected constructor, destructor, or type conversion before '(' token
SanityCheck.h:1523: error: expected constructor, destructor, or type conversion before '(' token
SanityCheck.h:1524: error: expected constructor, destructor, or type conversion before '(' tokenwhen i compile i get the following error:
Code: Select all
In file included from sketch\pins_GT2560_REV_A_PLUS.h:29:0,
from sketch\pins.h:176,
from sketch\MarlinConfig.h:34,
from sketch\G26_Mesh_Validation_Tool.cpp:27:
sketch\pins_GT2560_REV_A.h:34:0: warning: "BOARD_NAME" redefined [enabled by default]
#define BOARD_NAME "GT2560 Rev.A"
In file included from sketch\pins.h:176:0,
sketch\pins_GT2560_REV_A_PLUS.h:27:0: note: this is the location of the previous definition
#define BOARD_NAME "GT2560 Rev.A+"
In file included from sketch\MarlinConfig.h:40:0,
SanityCheck.h:829: error: static assertion failed: FRONT_PROBE_BED_POSITION can't be reached by the Z probe.
static_assert(FRONT_PROBE_BED_POSITION >= MIN_PROBE_Y, "FRONT_PROBE_BED_POSITION can't be reached by the Z probe.");
exit status 1
whit that file its compile and flash it .I3proC (3d touch A+ board).zip
(322.54 KiB) Downloaded 1575 times
and i verified ive got the T8 threaded rod . but someting happends on the LCD display when y send the z axis the values are erroneous.Note:
Check the threaded rod of your printer(Especially I3 PRO X, I3 PRO W, I3 PRO B, I3 PRO C)
If your printer working with T8 threaded rod
You need to send Gcode"M92 Z400" via USB port.(When you upload the firmware finished)
Then you need to send Gcode"M500" to save the setting.
