Problemas conexion GEEETECH PI3 PRO X CON EL PC
saulblas92
Post by saulblas92 »
Hola:
Os comento mi problema, he seguido los pasos marcados en el manual, he instalado el driver USB de la impresora, pero no me conecta con el ordenador, me reconoce la tarjeta SD pero no me la lee (SD de 2 Gb). No consigo hacer ni actualizar el Marlin, me da error timeout
Re: PROBLEMAS CONEXION GEEETECH PI3 PRO X CON EL PC
Hi, You can check if you have the correct port installed.
Can refer to this:https://www.geeetech.com/forum/viewtopi ... RlcFtWdCG4
Can you provide a specific screenshot of the reason for Marlin time out?
Maybe the serial port connection is incorrect and the correct baud rate is not selected,
which causes this to happen.
I found this, you can refer to it:https://reprap.org/forum/read.php?1,717917
