A20M not responding anymore
Posted: Sat Aug 24, 2019 6:24 pm
Hello guys,
im an absolut Beginner to the 3D-print sector.
I just wanted to get start printing with my A20M, as it turns out my first results were very bad, i think there are problems with underextrusion. After looking around i found out that a firmwareupdate could may solve the problem. So i tried to install the Firmware
A20M_Marlin-1.1.x12864 by Arduino but accidentally i installed the empty Sheet which opens when you start Arduino
. Now my device is not Responding anymore the LCD Screen is just blue, the Printer is connected to the PC but when i try to install the Firmware the following Error occurs.
I hope you guys can help me.
Code: Select all
Arduino: 1.8.9 (Windows Store 1.8.21.0) (Windows 10), Board: "Arduino/Genuino Mega or Mega 2560, ATmega2560 (Mega 2560)"
In file included from C:\Program Files\WindowsApps\ArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wtt\hardware\arduino\avr\cores\arduino/Arduino.h:28:0,
from sketch\MarlinConfig.h:38,
from sketch\configuration_store.h:26,
from sketch\configuration_store.cpp:190:
sketch\configuration_store.cpp: In static member function 'static bool MarlinSettings::Fixed_parameter_load()':
sketch\configuration_store.cpp:857:19: warning: unknown escape sequence: '\F'
SERIAL_ECHOPAIR(" \r\Fixed parameter nbytes; crc error ", (uint32_t)stored_crc);
sketch\serial.h:60:40: note: in expansion of macro 'SERIAL_PROTOCOLPAIR'
#define SERIAL_ECHOPAIR(pre,value) SERIAL_PROTOCOLPAIR(pre, value)
sketch\configuration_store.cpp:857:3: note: in expansion of macro 'SERIAL_ECHOPAIR'
sketch\MarlinSerial.cpp: In function 'println.constprop':
sketch\MarlinSerial.cpp:580:3: internal compiler error: Segmentation fault
Please submit a full bug report,
with preprocessed source if appropriate.
See <http://gcc.gnu.org/bugs.html> for instructions.
lto-wrapper.exe: fatal error: C:\Program Files\WindowsApps\ArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wtt\hardware\tools\avr/bin/avr-gcc returned 1 exit status
compilation terminated.
c:/program files/windowsapps/arduinollc.arduinoide_1.8.21.0_x86__mdqgnx93n4wtt/hardware/tools/avr/bin/../lib/gcc/avr/5.4.0/../../../../avr/bin/ld.exe: error: lto-wrapper failed
collect2.exe: error: ld returned 1 exit status
exit status 1
Fehler beim Kompilieren für das Board Arduino/Genuino Mega or Mega 2560.
