When ever I put in the sd card and tell it to print the x axis moves but the z + y axis don't
Can anyone help
y and z axis not working
Re: y and z axis not working
Hi, Can you describe your problem in detail?
Can you move the y/z axis by hand,
you can swap the x-axis motor line to the y/z axis motor to see if the motor is running normally,
or swap the x-axis drive board to the y/z axis drive board? Come up to check the situation.
I hope this can help you.
I can move the motors by hand and can use the move axis function on my printer (pursa i3 pro w) it's only when it goes to print that they don't work
Hi, You can check
1. Is your motor wiring properly connected, if the wiring is wrong, the motor cannot move;
2. If the wiring is correct, you can try to connect other axis motor wires to see if the motor is running normally.
You can also try to exchange the engine board to try.
you can refer to this:http://www.geeetech.com/forum/viewtopic ... 17&t=17038
Basically I can move the axis's by hand and they move when I use the move axis control I've tried switching the stepper inputs but it's the same it seems that only the x axis port/input move when I set something to print
Hi, Can you provide a video of your exchange operations and specific controls?
So that we can solve the problem better.
Sorry I cant the website won't let me
