Axe Y décalage impression A10M
vap38
Post by vap38 »
Good morning,
This printer A10M works since a complete length of about 20 hours.
Today it is breakdown enclosed of photographs to show problem.
It is about a gap of impression on the axle Y, breakdown is unpredictable according to the moèle but the height or problem starts mm of impression is in about in 3.
Afterwards it is of anything.
We can assume that the driver 4989 of the axle Y is at issue or the motor step by step? it is fundamental question.
I detain no experience in this domain, I really have prove the connectique and the free work mechanics.
Of what do you think of it? fje must turn the printer under guarantee or a refund?
thanks for your help
I proved all mechanical elements straps, pulley, tension of the strap, mechanical games of the tray, connectiques.
The motor 42SHD0034-20B does not heat up; the strap is undamaged.
I think more precisely of the faulty driver 4988 because defect always intervenes at the same height of impression (the cube of 20mm).
Conclusion according to my idea if impression is faulty in the same place we can agree on a repetitive thermal problem.
that I must make return the apparatus or wait for a new driver 4988.
What is your diagnosis?
a+
Re: Axe Y décalage impression A10M
Hi, For questions about y-axis layer shifting, you can check the following:
1. The tightness of the belt, make appropriate adjustments;
2. Whether the bearing or the pulley is issued, and the card can be lubricated for lubrication;
3. Whether the printing speed is too fast, can be adjusted appropriately;
4. Drive board voltage, can be adjusted (reference range 0.8-1.2V).
You can refer to this:
A4988 测量位置.jpg (192.77 KiB) Viewed 13810 times
I hope this can help you. :D
vap38
Post by vap38 »
thank you for my information.
This is the strap that is too tight like a guitar string.
The ideal travel speed is between 60 and 80% of the setting.
Weird at first the impression was correct!
now I am satisfied.
a +
fesiho6227
Post by fesiho6227 »
I think it is shortest part for a device using for this device and name of this device is above from my understand. First i have to find the name of this device and after that i should trying to learn https://www.college-paper.org/college-essay-papers/ for the part which we see here on the page it is really interesting.
magipa5558
Post by magipa5558 »
In the event that you see video, at that point you comprehend the significance of this printers portland oregon. On the off chance that you simply check this blog, at that point implies that every one of you are attempting to take more things which are simply great and significant for learning technique for work.
magipa5558
A few joins are not make reference to in great way. In the event that writer of the page is notice these connections in great public speaking coach, at that point all perusers comprehend it effectively where is significant for them. All the time we are attempting to discover these pages where we ever get great material for us.
emmamoore308
Post by emmamoore308 »
Thanks for a wonderful piece of information. I am a professional writer. I am willing to share a how to write a proposal for a grant. I am sure it will be helpful. See a guideline https://primeessays.com/how-to-write-a- ... ation.html
FrozenTina
Post by FrozenTina »
Thanks for sharing such useful information.
For this purpose, everyone at https://premiumqualityessays.com/poem-writing-service/ does what he knows best.
billyroberts
How to Choose a Reputable Paper Writing Service
Post by billyroberts »
Make sure to include a strong conclusion. This is the most important part of the essay and is the final word your readers will see. The conclusion should make your fast essay writing service think or feel something. If the reader can't relate to your point, they won't read your essay. Make it as compelling as possible! You don't want them to skip over it or move on to the next one. So, be creative and write your essay with these tips in mind.
leoholmes
Post by leoholmes »
Thanks for sharing
