Error sending command
Posted: Thu Oct 17, 2019 3:46 am
by Rush68
This happens to me when I send to print.
after three or four attempts already prints, I upload video, sorry, How can I upload a video?
Re: Error sending command
Posted: Thu Oct 17, 2019 9:25 am
Hi. you can provide the link address of your uploaded video.
So that we can solve the problem better.
Posted: Thu Oct 24, 2019 6:33 am
by Rush68
https://we.tl/t-iv9KfXsJHu
here is the link for the video,
this happens when i sent to print,
after several attempts print
Posted: Thu Oct 24, 2019 9:13 am
Hi,You can check the status of the limit switch,
connect to the printer via usb and enter M119 in the manual control of the Repetier Host.
You can refer to this:
http://www.geeetech.com/forum/viewtopic ... 13&t=17042
Posted: Fri Oct 25, 2019 3:01 am
by Rush68
In my case, everything is fine, I send home and everything is fine.
The same with the scripts.
the problem is that I send to print and everything is fine sometimes, but I often send to print and instead of going down after doing at home, it goes up
Sorry my english is very bad
Posted: Sun Oct 27, 2019 4:48 am
by Rush68
When send to print and instead of going home and then lowering goes to the coordinate in z 204.71, thats is the crash.
Posted: Fri Nov 08, 2019 12:43 pm
by Rush68
I solved the problem.
If I send to print from the sd card everything goes very well
thanks for your support
