New Firmware from Geeetech
dtouton
Post by dtouton »
What is that new firmware "G05" ?
Capture d’écran 2019-11-18 à 16.09.00.png (53.33 KiB) Viewed 6724 times
Re: New Firmware from Geeetech
Hi, It refers to firmware that does not contain 3d touch
dtouton
Post by dtouton »
The first line is :
A20M_G05 (support 3d touch) and the date is 2019-11-15
Oh, I thought you mean the second layer of G05.
The first layer refers to the firmware with 3d touch.
G05 refers to
It is an improvement and upgrades on the G04.
3DAngel
Post by 3DAngel »
But William, will it work with Gt2560-v3 + H340?
Since the G5’s. Does not mention the USB chipset, is it because now the main board are different?
Cheers
Hi, You can refer to this: https://www.geeetech.com/forum/viewtopi ... RlcFtWdCG4
Check if it is CH340.
To see if it works.
