About the three-color color mixing method of Color Mix
Locked
Admin
Post by Admin »
Hi, guys
something about the three-color mix software
Color mixing software for multi-mixing printer
Scope of application: win7/win8/win10
Supported gcode from:Slic3r, Cura, Easyprint3d and simplify3d. (Other gcode may support, but did not test)
Currently only available for Windows systems
the download link is :https://www.geeetech.com/download.html?download_id=40
and choose this:
Note: When the gocde file you loaded is wrong,
There may be a loading error or a software flashback
such as:
you can refer to this
Specific operation method:
wow,enjoy!
ThomasGee
Re: About the three-color color mixing method of Color Mix
Post by ThomasGee »
Every time I click on "mix color" the programm crashes without errormessage.
tried on twi systems
Win 10 1909 x64
gcode generated with Cury 4.4.0
Hi, If so, it may be caused by a gcode error,
When you slice it you need to turn off z hop.
pawien
Post by pawien »
turn off z hop ??
Hi, Extra ups and downs can interfere with the analysis.
Jarda3d
Post by Jarda3d »
I did not use color mixer (done in gcode by hand)...
But Z-hop 0.1mm is very needed for mixing extruder, at least at A10M. Try my actual profile, it was massive updated and you did not need to remove discs in hotend assembly. Sample gcode included for untouched printer (E-steps 340). Try to print the sample on A10T (with 340 Esteps of course).
A10 Slic3r profile: here
Locked
