I've installed 3D touch on my A20M, levelling works fine but when printing, the Z axis is not moving to compensate, what do I miss ?
Bed leveling : Z axis not moving while printing
Re: Bed leveling : Z axis not moving while printing
Hi, If you mean that the z axis is not compensated,
You can refer to this for calibration: viewtopic.php?f=27&t=18371
The specific operation video can refer to this: https://www.youtube.com/watch?v=_RtsZDbR2po
Yes that's what I mean, bed leveling works fine and output grid value. but it does not compensate while printing.Hi, If you mean that the z axis is not compensated,
I am stil not able to use bed leveling, any idea ? setting in Marlin 2.0 ?
here is the output of M420 V :
Here is the issue I got : https://github.com/MarlinFirmware/Marlin/issues/13512
But nothing help me on this thread
Code: Select all
Send: M420 V
Recv: Bilinear Leveling Grid:
Recv: 0 1 2 3
Recv: 0 +0.280 +0.221 +0.162 -0.080
Recv: 1 +0.060 -0.068 +0.056 -0.028
Recv: 2 +0.036 -0.036 -0.038 +0.033
Recv: 3 -0.223 -0.157 -0.038 -0.033
Recv:
Recv: echo:Bed Leveling ON
Recv: echo:Fade Height OFFBut nothing help me on this thread
Hi, Does this happen when you print all models?
Can you provide your specific video?
Yes it happen with all models, even when I add "M420 S1" after "G28" on the starting gcode and I am sure the bed leveling data are ok because when I do a "M420 V" while printing it output the mesh leveling datas, I am really lost on this issue...William wrote: Mon Dec 09, 2019 6:14 pm Hi, Does this happen when you print all models?
Sorry no video but the issue is simple : z axis is not compensated while printing (it is not moving while printing a layer)
