New a30 hotend not working
Posted: Thu Dec 26, 2019 11:01 am
by mfann72
I just set the printer up today, and the hotend worked for about 5 minutes then started cooling down. Now it will not heat up. Any ideas?
Re: New a30 hotend not working
Posted: Thu Dec 26, 2019 11:12 am
Hi, Are you referring to the temperature display on the screen?
Or the hot end itself?
You can check whether the hot-end connection is fully connected;
Use a multimeter to measure the thermistor at the hot end;
If you do n’t have a multimeter, you can unplug the hot end cable from the motherboard.
Check the screen temperature display. If it shows -14, it is determined that the motherboard is normal.
I hope this can help you.
Posted: Fri Dec 27, 2019 1:06 am
by mfann72
Thank you. Got it working. printing my first part now. Was a loose wire at the hot end.
Posted: Fri Dec 27, 2019 9:05 am
Glad you found the solution.
