Prusa I3 Pro B Acrylic Z Axis issues ..!!
miguelpikons1
Post by miguelpikons1 »
Hello guys,
yesterday i've juste finished to build my prusa I3 Pro B Acryclic, X and Y Axis work well but ...µ
...it's not the same for the Z axis ...
Nothing's moving, I can ear the step motor trying tu turn but it look like it's stuck somewhere ...
Any ideas ?
Re: Prusa I3 Pro B Acrylic Z Axis issues ..!!
:D Hi, If it refers to the z-axis not moving properly,
You can check the following:
1. Whether the z-axis screw is bent, if it is bent, it will need to be replaced;
2. Whether the coupling is installed correctly;
3. Whether the left and right z-axis are at the same horizontal line, if not, they need to be adjusted;
4. Whether the brass nut installation is too tight, you can try to adjust it.
For specific operations, you can refer to: http://geeetech.com/forum/viewtopic.php?f=82&t=60931
I hope this can help you.
