Need some help...I'm beginer
burgraf_yann
Post by burgraf_yann »
I begin with printer.
I have intalled my printer and I print the dog test fine
I install curra and I configure it with resources find in this forum
I try to print yoda
https://cults3d.com/fr/mod%C3%A8le-3d/a ... 3d-designs
I stop the print because I see that a part of the piece is broken (see the picture)
Some body can explain me whats happen?
The temperature are not OK? I keep the default value....(200)
Re: Need some help...I'm beginer
:D Hi, You can check if your nozzle is clogged,
You can try to heat the temperature to 200 and then manually push the consumables,
Clean it up in a timely manner if it is blocked;
Printing speed reference range: 30-60mm / s;
The print temperature is set to consistent.
