Z Axes step motor issue
fabry_mf
Post by fabry_mf »
Hello to everyone,
I build my 3d printer following this yt series (https://www.youtube.com/watch?v=BPfFqAp ... _DPNh3KWgj) but I have an issue with Z axes step motor.
When I turn on my 3d printer and I go to Prepare > Move Axis > Move 1 mm > Move Z both z axes step motors try to turn themself but they can't.
It's not a eletrical issue, because I try both step motors without alone and they works.
If I try to turn them with hands, they do it, not smoothly (the others two step motor turn smoothly) but they turn.
I think the two lead screws doesn't turn correctly inside the z-axis nut.
Is it possible? If the problem is this, what I can do for correct the behaviour?
If not, what can be the problem? A settings, maybe?
The video series I mentioned above is not very clear and I'm not sure about how much millimeters lead screws must be inside the coupling or how much millimeters step motor must be inside the coupling. But, I said it before, with hands both step motors turn themselves correctly.
Help please :)
Jarda3d
Re: Z Axes step motor issue
Post by Jarda3d »
Hmm, I look that Geetech made very good changes to original Prusa....
At your problem - I think that it is misaligned rods.
See at Original Prusa crap:
Original PRUSA i3 MK2 crap.jpg (201.62 KiB) Viewed 18718 times
A10 Slic3r profile: here
