Me Creator 2 aluminium plate
8ung
Post by 8ung »
Hi GEETECH guys
any explanation, why your spare part https://www.geeetech.com/mini-aluminum- ... p-878.html
is shrunken.
My original plate has 180x180mm
thats neccessary because printing volume is 160x160mm
pse for Info
tnx
Re: Me Creator 2 aluminium plate
:D Hi,thanks for your feedback.
maybe changed size but not adjusted,
you can print in the range of the hotbed.
8ung
Post by 8ung »
Ah I see there was a Mecreator , without "2", never seen this before :-)
Ok this plate should be for the old modell
But where is the plate for Mecreator 2
Do you have a link William
tnx
8ung
Post by 8ung »
any hints William ?
VonRueden
Post by VonRueden »
I just put an order on eBay for an aluminum build plate for my Replicator2. The build plate that comes with the rep 2 is acrylic. It's tough to level the acrylic plate since its slightly warped. I think it has a minor hump in the center since leveling the front and the back knobs to a paper height distance between the plate and extruder, causes the center of the platform to be too close the the extruder. Has anyone done the aluminum upgrade?
My AARP Medicare
