Filament stuck on printer
Posted: Sun Feb 02, 2020 11:06 pm
by Aquasheep
I have problem with filament. Its broken somewhere inside the printer in white tube that leads to nozzle.
How I get it out. Video in YouTube where u replace the nozzle has different nozzle. My printer is bit different.
my printer looks like this.
Re: Filament stuck on printer
Posted: Mon Feb 03, 2020 9:44 am
Hi,Do you mean that the consumable is broken in the middle? You can remove the Teflon tube and remove the broken consumable. The nozzle can print normally?
Posted: Thu Feb 06, 2020 4:09 am
by Aquasheep
Yes its broken inside the teflon tube. So how i remove the teflon tube? Just pull hard or?
Posted: Thu Feb 06, 2020 8:56 am
Hi,Remove the connected segment and see if the supplies can be removed.
Posted: Sat Feb 15, 2020 3:32 am
by Aquasheep
So how i remove the teflon tube? Will I pull hard or do I need to do something first?
Posted: Sat Feb 15, 2020 9:00 am
Hi,you can try to unscrew the Teflon tube connection position on the motor side
Posted: Tue Feb 18, 2020 9:22 pm
by Aquasheep
Is it possible to remove the teflon tube from nozzle end? Or how I remove the nozzle? Video in youtube has machine that is different than mine.
Posted: Wed Feb 19, 2020 9:27 am
Hi,if you use such a nozzle, you can use a tool to remove the nozzle at a temperature of about 200 °.
