Motors without force
Posted: Sun Mar 08, 2020 7:08 pm
by TheT
The problem is that the motors that move the z axis do not have enough force to lift the extruder and generally lose steps, lower well, the extruder also does not have force, so I have to put it at high temperatures and low speed so that it does not lose steps
Re: Motors without force
Posted: Mon Mar 09, 2020 7:01 am
Hi,is your z-axis installed correctly and is the threaded rod bent? Whether the brass nut is installed too tightly, the coupling is installed correctly, and the left and right z-axes are on the same plane. If the motor itself cannot run normally, you can try to exchange the motor wire to see.
Posted: Mon Mar 09, 2020 4:38 pm
by TheT
William wrote: Mon Mar 09, 2020 7:01 am
Hi, the bars do not seem bent, the cables are new, because recently I have the printer and I stop giving it strength, I think for an update, I already updated it in several versions and it remains the same. and thanks for answering quickly.
Posted: Sun Apr 12, 2020 1:08 am
by miguelopomelo
Hi.
I had the same problem when I first mounted the machine. I could stop the motor movement with a finger without force. The cause was the z axis motor driver (A4899) was defective, change it for a new one and problem solved
