Which connector does the thermistor connect to on a A20M
Posted: Mon Mar 30, 2020 11:22 am
by Hopsing
I got a A20M and have figured out that it is missing the thermistor. Where can I get one. Can anyone tell me which connector the thermistor plugs into? I think it plugs next to the green connector which goes to the heater itself. There is a two and a three prong connector vacant, and I suspect it does connect to the two prong connector. Any help will be very much appreciated. Hopsing
Re: Which connector does the thermistor connect to on a A20M
Posted: Mon Mar 30, 2020 11:30 am
Hi, Can you provide a picture of your adapter board
What else is missing the thermistor
Hot end or hot bed?
Posted: Mon Mar 30, 2020 1:21 pm
by Hopsing
Yes I can provide a picture but I don't know how to upload it. It is a jpeg file.
Posted: Mon Mar 30, 2020 1:22 pm
by Hopsing
Yes the thermistor is the only thing that is missing. Heater is ok I think. I know where it connects it is color coded (green).
Posted: Mon Mar 30, 2020 1:27 pm
by Hopsing
- hotendimage.jpg (185 KiB) Viewed 7512 times
Posted: Mon Mar 30, 2020 2:07 pm
Hi, You can see if there is a heating rod,
You can refer to:
- 转接板介绍.png (305.75 KiB) Viewed 7511 times
Posted: Tue Mar 31, 2020 5:12 am
by Hopsing
William thank you so much for the detail image. I thought that was the plug but I wanted to make sure. I now have a heated bed and heat to the nozzle but no movement from the stepper motors or extruder units. Any ideas as to what to check here? I am a newbie and I am sorry that I am a pain. Been trying for a month to get this printer up and working.
Posted: Tue Mar 31, 2020 10:40 am
Hi, do you mean the extruder can't heat up or the extruder motor can't move normally?
The reason the extruder can't heat is that you haven't terminated the heat,
If the extruder motor cannot move, you need to check whether the wiring on the motherboard is correct.
If it is correct, you can exchange and check with the motor wires of other shaft motor ends to confirm whether it is a problem with the motor wires of the extruder.
