The Firmware Upgrador shows:
Installed Version: V1.0.05
Newest Version: V1.0.04
Installed is newer than the newest?
What is wrong?
Wrong display of firmware I3 pro W
- firmware.png (5.33 KiB) Viewed 12240 times
Re: Wrong display of firmware I3 pro W
Hi, you can download the firmware from this:https://www.geeetech.com/download.html?download_id=36
What is the newest / most current version?
Hi, it is v1.0.05.
you can see from here:
Thank you for the quick and detailed answer.
Unfortunately, you have not yet understood the problem.
I see the latest / current version is V 1.0.05. I installed this version. You can see that in the window below
Installed Version: V 1.0.05
Version V 1.0.04 is older than V 1.0.05. Version V 1.0.04 cannot be the latest version, as in the window below
Newest Version: V 1.0.04
Incorrect display
Correct display
Newest Version: V 1.0.05
Incorrect display
Correct display
- firmware.png (4.89 KiB) Viewed 12217 times
