EasyPrint3D aborts when slicing - without an error message
JRichi
Post by JRichi »
I have Windows 10.
Slicing seems to start correctly. Before the progress display starts, the EasyPrint3D program breaks down completely. Without an error.
The button Done! I can’t click. The gcode file is also not yet created.
What can I do?
Re: EasyPrint3D aborts when slicing - without an error message
Hi, can you provide your stl?
and you can try slice another model.
you can use Repetier Host to slice.
JRichi
Post by JRichi »
Hi William
the program always stops with the *.stl:
Program example files: deer.stl, case.stl
ASCII: comp01.dae_A.stl, test3.dae_A.stl
Binary: comp01.dae_B.stl, test3.dae_B.stl
I think the problem is not with the files.
I am a newbie.
What you mean with "... use Repetier Host..."
With Ultimaker 4.5 I can create the *.gcode files from the *.dae files. There are no problems.
Regards Juergen
dateien.zip
(18.11 KiB) Downloaded 601 times
JRichi
Post by JRichi »
Hi Wiliam,
I reinstalled the EasyPrint 3D program and the printer driver.
The result is the same. Slicing stops without an error message.
Wenn ich das Slicing mit Ultimaker Cura 4.5
If I do slicing with Ultimaker Cura 4.5 then I can easily load the *.gcode file.
I have linked the *.gcode extension to the EasyPrint3D program.
When I double click on a *.gcode file I get an error message:
System.IO.FileNotFoundException: img/Disconnect.png
bei System.Drawing.Image.FromFile(String filename, Boolean useEmbeddedColorManagement)
bei RepetierHost.view.ThreeDControl.UpdatePrintPanel(Object sender, EventArgs e)
bei System.Windows.Forms.Timer.OnTick(EventArgs e)
bei System.Windows.Forms.Timer.TimerNativeWindow.WndProc(Message& m)
bei System.Windows.Forms.NativeWindow.Callback(IntPtr hWnd, Int32 msg, IntPtr wparam, IntPtr lparam)
The program can then no longer be continued.
I would be very happy to receive a response.
Regards Juergen
