Geetech a10m x-axis belt motor slide
Wfire
Post by Wfire »
I have my belt which makes a left right on the notched wheel of the x axis, I try everything to center the belt, tighten, loosen, check the right fastener (right side). I even add guides but it is still right to left. since what made it (new 1 month) I have my first layer that exceeds (same piece from the beginning, same stl.)
Re: Geetech a10m x-axis belt motor slide
Hi, Layer shift
You can check
Is the distance between your nozzle and the hot bed the leveling paper?
Is the printing speed too fast,
Whether the bearing and pulley are issued, and the card is lubricated with lubricating oil,
The tightness of the belt,
You can refer to the belt adjustment method: https://www.youtube.com/watch?v=QmrT1sPhvf8
Wfire
Post by Wfire »
William wrote: Sat Apr 11, 2020 9:30 am Hi, Layer shift
You can check
Is the distance between your nozzle and the hot bed the leveling paper?" Ok"
Is the printing speed too fast, "same speed before and after"
Whether the bearing and pulley are issued "you mean the pulley screw well, push in the motor axis ??"
, and the card is lubricated with lubricating oil, "what card are you talking about"
The tightness of the belt, "ok"
You can refer to the belt adjustment method:" ok "https://www.youtube.com/watch?v=QmrT1sPhvf8
Wfire
Post by Wfire »
I have never had so much problem with a printer, and she and NEW, big big design problem for the x axis
Wfire
Post by Wfire »
7 days for one belt
after sale service please
25mm/s ok
url=https://zupimages.net/viewer.php?id=20/15/tj6d.jpg]Image[/url
Wfire
Post by Wfire »
impossible to settle
the strap always goes to the same place whatever I do
extruder direction control panel (right) = full motor belt
extruder to motor x = belt to the outside
Hi, Can you provide videos?
Wfire
Post by Wfire »
Belt die?
