Geeetech E180 - the touch screen does not respond
Posted: Thu Apr 23, 2020 7:29 pm
by jesusj
Turning on the printer, the menu appears, but the touch screen does not respond. it's my second day with the printer.
yesterday, I threw the packaging thinking that everything was going well, what could happen ?.
Well, what can I do?
Re: Geeetech E180 - the touch screen does not respond
Posted: Fri Apr 24, 2020 11:26 am
Hi,you can check if the wires are not connected.
Posted: Thu May 21, 2020 7:37 pm
by ivaanadam
I am also facing this touchscreen not responding issue with my printer.
Boost 4g signals Why this is happening and how can I fix this problem? Anyway, your post is really informative and I hope your post will help me to fix this issue.
Posted: Fri May 22, 2020 9:58 am
Hi,the 4G signal should have nothing to do with the screen, you need to replace a screen, you can contact the salesperson on the purchase platform.
Posted: Thu May 28, 2020 3:32 pm
by jesusj
I did a thousand tests, in which I managed to get the screen to work, touching cables, installing the latest firmware, but I stopped seeing the files stored on the sd, finally the screen ended up dead after loading the different firmware.
I finally bought a new screen which came to me yesterday. right now it's in the printer. Now I can see the screen but I still cannot access the files saved in the sd.
I am currently using a raspberry pi with octoprint to be able to print with the printer. From octoprint I can see the files that are in the sd. but there seems to be no communication between the display board and the printer board.
Finally, if I can't get the printer to print on its own, I'll change the control board for a third-party one, since the platform and motors are the only thing I can take advantage of.
Posted: Thu May 28, 2020 4:45 pm
Hi,try to loosen the screws on the screen, it may be too tight.
