M201 GTM32 vA source code
I have a M201 with a GTM32 vA board and am needing the source code for the firmware so that i can move the hotbed pin to one of the un-used E1 or E2 pin locations, as the silk screen tracings on the board has failed. I have read the post and done all the test and the mosffet works properly but there's no output to the pins on the board. This is a 12v board, and 12v heat bed, that has to heating elements and they and the temp sensors all are good. If any one can help it would be greatly appreciated.
Re: M201 GTM32 vA source code
sorrry there is no source code, it is recommended that you replace the motherboard.
