I have burnt my A6SHB Fan0 Transistor on my new GT2560 V4
cabfire
Post by cabfire »
Hello everybody,
By changing my cooling fan on a Geeetech A10 with new GT2650 V4, I have made a mistake and created a shortcut :-(
So the Fan0 A6SHB transistor on the mother board has burnt :-( and now I have 5V instead of 24V tension on Fan0 power out.
Do you know a way to connect the "Adapter Hot End plate" to the Fan1 power out of the Mother Board ?
I guess repairing should be too difficult to change the transistor. Finaly the best way should be replacing the mother board but I think we can simply use the second Fan no ?
MB Burnt Transistor.jpg (53.48 KiB) Viewed 8158 times
Re: I have burnt my A6SHB Fan0 Transistor on my new GT2560 V4
Hi,you can directly change the interface to Fan1 or Fan2.
cabfire
Post by cabfire »
Hello William
Thank you for your prompt answer.
I have plug my fan on other interface of the "Hot End Plate Interfaces" as you can see on photo (Num 2 output)
But I have only 5V here and gcode instruction seems not working (M106 P1 S255 for example, the same with P2)
Num 1 was the output interface used for fan when I burnt the transistor. I have only 5V here and gcode instruction M106 S255 doest not work anymore.
Finally I use the num 3 interface but it is not possible to manage it with M106 S0 or S255 gcode with P value at 0, 1, 2 or more.
I guess the both 1 and 2 outputs of the "Hot End Plate Interface" is powered by the single mother board Fan0. And output 3 is like the output below itself and probably powered by another MB power output (other than fan0,1 and 2 MB outputs)
But May be you wanted to talk about Mother Board Interface to change directly fan 1 or 2 ? In this case, is there a way to change from fan 0 to fan 1 or 2 and power the "Hot End Plate interface" for the cooling fan (See photo 2 of Mother Board) ? It should be possible no ?
Thank you again
Fabrice
Hot End Plate Interface.jpg (35.91 KiB) Viewed 8088 times
Hot End Plate Power.jpg (54.04 KiB) Viewed 8088 times
Hi,if the fan is not controlled, you can only replace the motherboard.
cabfire
Post by cabfire »
yes Fan for Nozzle is not managable :-(
I have ordered a GT2560 V4 just right now on the geeetech web site.
Hope it arrives quickly because for the moment I have temporarly made a manual workaround (see photo) to switch on/off the cooling Fan :-)
manual workaround.jpg (68.94 KiB) Viewed 7620 times
:D
