Turning up heated bed to maximum.
unclebill
Post by unclebill »
I'm about to remove damaged glass plate and replace it. The only suggestion I've had is to heat the bed up to maximum and, using a steel guitar string, slide it between the glass and the bed when the glue is very hot and it should come off. Not knowing where to look, I have no idea how to turn up the heat of the bed. Can someone please help?
Re: Turning up heated bed to maximum.
Hi,you can Select Control-Temperature—Nozzle on the screen.
