Page 1 of 3
Upgrading from A30M to A30T - No UI upgrading
Posted: Sat May 16, 2020 6:30 am
by ktown1900
I have successfully updated my A30M to an A30T(info shows A30T). Only the display UI files don't show the correct parts(mixing interface with 3 extruder) of an A30T.
I follow the step by step guide at the firmware on the side.
-> Put the system and the A30T_S02_V1_01.bin to root card.
-> add a config.txt (with boot:1;bin_name:A30T_S02_V1_01.bin;) to root of sd card
-> start printer again
-> nothing happen
I checked the usb port on the side and directly on the mainboard.
What can I do? Any helps?
Re: Upgrading from A30M to A30T - No UI upgrading
Posted: Mon May 18, 2020 10:07 am
Hello, you can try to drag the system file into the SD card, don't forget to delete other contents on the SD card,
and then insert the SD card into the card slot.
Remember to remove the SD card after the update.
Posted: Tue May 19, 2020 6:04 am
by ktown1900
I did it but with no action. You mean the system file from the update?
Any other files on the sd? Without config?
Posted: Tue May 19, 2020 9:27 am
Yes, you need to put the entire system file into an empty SD card and then insert it into the card slot.
Posted: Wed May 20, 2020 3:43 am
by ktown1900
I do this. But the printer do nothing.
Posted: Wed May 20, 2020 4:45 am
by ktown1900
I put this on my sd card. Insert it in my A30M printer. But there are no action on my printer.
Is there anything to do on the printer menu? What happen when it starts?
Posted: Wed May 20, 2020 11:15 am
1. Update motherboard firmware
2. Update the screen program and UI. Your previous operation is correct, but the SD card needs to be inserted into the card slot of the screen.
A30T firmware version V1.01.01
Motherboard application: A30T_M09_V1_01.bin (CRC32: A472CDCC)
LCD screen application: A30T_S02_V1_01.bin (CRC32: E0A6016E)
The mainboard application uses the "firmware_tool_V2.0" burning tool for burning and must be the firmware_tool tool of V2.0 or later.
This is how to update the screen program and UI:
FileRecv.rar
(158.33 KiB) Downloaded 493 times
Posted: Fri May 22, 2020 5:42 am
by ktown1900
I use this manual a lot of times. But there is no update of the ui.
Any chance to do it on another way?
Posted: Fri May 22, 2020 10:19 am
Hi,did you add a space when editing?this is not acceptable.
Posted: Mon May 25, 2020 3:17 am
by ktown1900
Can you send me the completely files on the as card. No space on it.
