Temperature is very unstable
toxic
Post by toxic »
Extruder and bed temperature is very unstable. Even if extruder and bed are cold the temperature is changing +-2.5 degree. It is not normal.
Re: Temperature is very unstable
Hi,maybe you should adjust the PID, you can refer to this:https://reprap.org/wiki/PID_Tuning
toxic
Post by toxic »
I already did it, many times, it doesn't help.
Hi,you can pull the thermistor out of heater block to check whether the rubber tube covers the thermistor itself.
