A10 w/GT2560 V3 replacement LCD showing black bars?
AlexanderMason
Post by AlexanderMason »
Hi all.
While dinking around with my display, I managed to jank my LCD so that the top row is blank and the second row is incomplete.
I ordered a replacement from Geeetech and, as stated on their purchase page, noted that I needed the LCD for the GT2560 V3 board. I received the replacement but when I connect omegle xender it to the display cable it shows only two solid bars.
What am I missing? Do I have the wrong LCD?
Yes, I am sure I have a V3 board. I'm running Marlin 1.1.8.
Last edited by AlexanderMason on Fri Jun 19, 2020 1:56 pm, edited 1 time in total.
Re: A10 w/GT2560 V3 replacement LCD showing black bars?
Hi, can you provide the pictures displayed on the LCD?
gerald__evans
Post by gerald__evans »
I have one site about to Get FREE Unlimited UC and BP Coins in PUBG Mobile, I can share that with if you want to know about that you can check here. PUBG Hileleri
nalafxx
Post by nalafxx »
Underscan occurs when a video signal does not reach the edges of your monitor and leaves a black border around the image. Normal broadcast TV content is "overscanned," meaning the image bleeds/scans past the edges of the screen so it fills the entire monitor.
viva tv apk
manishacc
Post by manishacc »
We have a page on PUBG Mobile free money for UC and BP that I can share here if you want to know if you can check it out.
fmwa
cinema hd
jamesdon
Post by jamesdon »
AlexanderMason wrote: Wed Jun 17, 2020 9:11 pm Hi all.
I ordered a replacement from Geeetech and, as stated on their purchase page, noted that I needed the LCD for the GT2560 V3 board. I received the replacement but when I connect omegle tv it to the display cable it shows only two solid bars.
if your A10 or A10M printer LCD do not looks like this, and is GT2560 V3.0 control board, you need LCD 700-001-0996, and LCD cable 37-001-0224. they are not listed on the store, you can buy this and leave a comment for your order you need LCD and cable compatible with GT2560 V3.0 board, we will change your odrer for you, send you the right one. Description LCD 2004 display is a basic 20 character by 4 line dot matrix controller module designed for different 3D printer motherboard. The product contains 20 Character x 4 Line LCD display, a rotary encoder. There is a SD Card slot on the back of the LCD Module, connecting it with the controller board of 3D Printer. Just insert your SD card into the SD slot, you can print 3D models without PC.
