hi.
i use cura 4.9.1. and geeetech A20m.
the prints are stopped shortly befor the print is completed. mostly 97 to 98 finished.....
i found no solution...
any idea??
thx
printing stopped at 97 to 98 % before end of process
Re: printing stopped at 97 to 98 % before end of process
Hello, are you printing a multi-color model? If so, the temperature of the extruder may be too low during the refueling process, causing cooling. You can increase the temperature to prevent printing failure.
Or the problem with the TF card, you can try to print online, or replace the Tf card.
Since they have a thermal cutoff, your extruder will stop working in the middle of your print if the temperature gets too high. The only way to resolve this issue is to turn off the printer and allow the electronics to cool down. To avoid the problem completely try adding an extra cooling fan.alfvv12 wrote: Sat Jul 17, 2021 6:08 pm hi.
any idea??TelltheBell
thx
