Geeetech i3 Pro W Calibration/Extrusion issues
birbajans94
This printer has been a pain in the neck for nearly a year, to the point where I had to use a second printer to print a fix for the Z axis binding and update an option in the firmware to get the travel on said Z axis correct. Since then I've had quality issues, I'll link the imgur album showing two battery cases I've tried to print that show under extrusion that I'm not sure how to fix as well as a benchy that I have no clue what's wrong with it. I should be able to provide the applicable Cura settings, they're both printed in 3D Solutech PLA at 200c with 60c bed temp (no adhesion issues).VidMate Mobdro
JamesGaddis
Re: Geeetech i3 Pro W Calibration/Extrusion issues
Thank you so much for the extruder help and that would be pretty useful to all. Through the article we able to fix the problem with our printer easily. Thumbs up and do share further samedayessay review updates with us these are useful to all.
