Dual Extrusion Issue (GeeeTech i3 Pro)
Posted: Mon Oct 04, 2021 2:16 pm
by milowbrac
I recently bought a GeeeTech i3 Pro C, the one I recently posted about. I’ve been working on it ever since I got it. Fixed all the wiring, put a new heated bed on it, put some printed spool holders on it. I recently update the firmware and I had an issue with the z axis moving 1/10 of what it was supposed to. I finally got that fixed and got the right firmware again. However, I have a new issue now where Extruder 1 will extruder 10mm if I manually make it. But if I try to make Extruder 2 Extruder 10 mm, it will Extruder 100mm of filament. I have no idea what could be causing this. I did upgrade to the DRV8825 motor drivers as well. But everything is working fine except the second extruder and I am very puzzled by it.https://9apps.ooo/
