Z Axis moves
Posted: Wed Dec 29, 2021 2:45 am
Hi All,
When tell the z to move up or down 100mm I get a little less then 25mm.
I checked the voltage of the motor driver and is at 1 volt ...
M8 Rod as supplied, and the z steps/mm is 2650
Movement is smooth and does not seems to have an issue, also the coupling is not slipping.
