Firmware for bltouch
Posted: Fri Dec 31, 2021 3:59 pm
My i3 pro w works great.
Got some nice prints even some miniatures turned out really great.
Nevertheless I wanted to upgrade the printer with a bl touch.
1) is there a custom firmware for the pro w with bl touch implemented? I only found one for the pro b
2) is there a specific mount you would recommend?
3) is it even possible to use pre configured mount/firmware or do I need to calibrate it my self for sure?
4) im not 100% sure which version of the bl I'm having since the shop labeled it as 3.0 but the back of the sensor got 3.1 written on it. Does it matter for installation?
4) also I downloaded the cura profiles from geeetech but other than the screenshot there is no i3pro in the list.
I used the generic i3 profiles but at leastshowbox speed test
the buildhight is different so not sure if anything else needs changing...
Thanks in advance for your help and all the work you doing.
