Code: Select all
// Steppers
#define X_STEP_PIN         37
#define X_DIR_PIN          39
#define X_ENABLE_PIN       35
#define Y_STEP_PIN         31
#define Y_DIR_PIN          33
#define Y_ENABLE_PIN       29
#define Z_STEP_PIN         25
#define Z_DIR_PIN          23
#define Z_ENABLE_PIN       27
#define E0_STEP_PIN        46
#define E0_DIR_PIN         44
#define E0_ENABLE_PIN      12
#define E1_STEP_PIN        49
#define E1_DIR_PIN         47
#define E1_ENABLE_PIN      48GT250 v3 schematic suggests the following:
Code: Select all
E0motor
EX_EN 51 PG0 (WR)              = pin 12
EX_STP 41 PL6                  = pin 46
EX_DIR 39 PL4(OC5B) PWM        = pin 44
E1motor
A_EN  36 PL1(ICP5)             = pin 48
A_STP 35 PL0(ICP4)             = pin 49
A_DIR 37 PL2(T5)               = pin 47
E2motor
E2_EN 25 PB6(OC1B/PCINT6)      = pin 41
E2_STP 38 PL3(OC5A) PWM        = pin 43
E2_DIR 40 PL5(OC5C) PWM        = pin 45
- In software "E0_" variables refer to the pins of E2motor in the schematic, which matches silkscreened "extruder 2" print on the board.
- In software "E1_" variables refer to the pins of E1motor in the schematic, which matches silkscreened "extruder 1" print on the board.
- In software "E2_" variables to the pins of E0motor in the schematic, which matches silkscreened "extruder 0" print on the board.
As "extruder0" does not have a connector soldered, it is omitted from file "pins_GT2560_v3.h"
As I need 3 extruders defined I had to add "extruder0" manually:
Code: Select all
#define E2_STEP_PIN        43
#define E2_DIR_PIN         45
#define E2_ENABLE_PIN      41
