Thermal Runaway A10M
Haroldsplace
Hello, today i've got a error message.
After a few minutes, print is already started, the temperture slowly dropping and the printer stops.
My best guess is a foulty thermistor.....its 600K Ohm.
Is it possible to replace tis one?
Anyone a better idea?
Cheers,
Harold.
Cheers,
Harold.
Re: Thermal Runaway A10M
Hi, You can check if your thermistor wiring is loose,
It can be measured.
The normal room temperature is at 80kΩ.
It can be measured.
Haroldsplace
Hi William,
Well the wires look oke, massure 600K ohm,it's a circuit but to high.
When i disconnect the wire i'll get -14C.
Do you know what the Ohm' is at 220C?
Maybe i can find a themporary replacement, till the new one arrives from Geeetech.
Hi, You can use a multimeter to measure thermistors.Haroldsplace wrote: Tue Mar 31, 2020 1:33 pm Hi William,
Haroldsplace
I did use a multimeter to measure the thermistor and i've got 600k Ohms.
So i maesure something but it's way too high i guess.
you need change it.it is too high.Haroldsplace wrote: Tue Mar 31, 2020 9:53 pm I did use a multimeter to measure the thermistor and i've got 600k Ohms.
Haroldsplace
Oke, got a new termistor today, but about 10 minutes later, i got the same error.
Your printer's firmware reported an error. Due to that OctoPrint will disconnect. Reported error: Thermal Runaway, system stopped! Heater_ID: 0 - Printer halted. kill() called!
What have i forgotten?
Edit:
Did a PID setup....no joy.
But it seems that the error starts on the secound layer.
Then the tempeture drop slowly untill the error.
Edit:
Hi, You can try to update the firmware,
See if this happens again,
Is it possible to print the test files in the SD card normally?
Haroldsplace
Your the man.... you've got me thinking.
Law of murphy.
Termistor broken and faulty software.
This time the print finished it's job.
Gonna try to dial in the settings.
I'll be back.
Thanks.
Law of murphy.
I'll be back.
Thanks.
Haroldsplace
Everything back to normal, case closed.
Thanks William.
Thanks William.
